AWS freezing since upgrade to v18
Tim Butcher
Our AWS install is freezing every few days since upgrade to v18, it was rock solid previously. I see there is a similar thread for Linux VM but is there a fix for AWS?
Many thanks.
Tim
I would consider a backup, redeploy your AWS and restore then look if the problem persists.
If it is something that will get resolved by taking a backup and redeploying then that would definitely be the quickest and best method, but, before you do, you could take a quick look at things like:
• Available Disk space
• CPU Usage
• RAM usage
• Allocated Resources
• etc
Well at the end of the day, AWS is a linux VM so that fix may apply, although you didn't link the thread so not sure what that fix is. My best guess is that swap is not enabled on that AWS instance.
gmacinit
