AWS Lightsail Ports
The Chief
I've trialling AWS Lightsail and i have the below ports configured. The 3CX system has 6 phones on it, 4 are using an SBC at one office, but the 2 other Yealink T48G phones are going to use STUN. If i change UDP 5060 to be locked down to Gamma SIP trunk, it stops the STUN from working, should i only set a firewall rule for incoming on UDP5060 to Gamma? Not too sure where in AWS Lightsail that i can only have an incoming rule for 5060 UDP.
Add rule
ApplicationProtocolPort or range / CodeRestricted to
SSHTCP22Any IPv4 address
Lightsail browser SSH/RDP
HTTPTCP80Any IPv4 address
HTTPSTCP443Any IPv4 address
CustomTCP2528Any IPv4 address
CustomTCP5001Any IPv4 address
CustomTCP5015Any IPv4 address
CustomTCP5060
5061
Any IPv4 address
CustomTCP5090Any IPv4 address
CustomUDP5060Any IPv4 address
CustomUDP5090Any IPv4 address
CustomUDP9000
10999
Any IPv4 address
Hi @The Chief,
Are the IPs at the STUN site static or dynamic?
Are you unable to set up multiple rules here? I didn't understand.
Also please note that the following ports can be removed from the list:
  1. 80
  2. 5015
  3. 5001 (IF you are using 443)
They will be dynamic but i could set them as static if needed.
I'll delete the ports 80, 5015 and 5001 as i am using 443.
I can setup other rules, but it doesn't have inbound and outbound rules. I was concerned in just locking down port 5060 for my sip trunk provider?
If they could be set to static IPs, why not do so and then whitelist them?
Alternatively you can use a SBC.
Thanks VasilisV i will set them as Static and add them to the whitelist. Thanks for your help.
No problem @The Chief, let me know if you have any problems.
Tech_Support
