AWS S3 Integration with v20U7
George_WB
I updated 3CX to latest U7 this weekend and I am now in the process of integrating with AWS. Everything looks fine, I can see the subfolders inside the bucket I created and given the permissions as specified in 3CX documentation and IAM Config File through the Console. After running the manual Move to Archive and also trying to run a backup it seems that nothing is pushed in the S3 Bucket.
Are there any logs in 3CX that might show if there is any issue between the 3CX-AWS integration?
Thank you!
Just to avoid chasing something without cause, was this earlier today, as AWS had an outage affecting many things? Or just now?
You might have to stick it in verbose logging to see if it outputs anything.
also, theres been an issue with AWS today as seen in the news - could be related.
Issue persists. I am using eu-west-2 and issue was in us-east-1 so I don't believe should be affected.
Below is the only log I can find. I am also using the Linux ISO of 3CX just for reference.
In the same installation I had issues with Sharepoint aswell, thats why AWS integration was my next option
2025/10/20 15:11:06.657|0035|Erro| [_3CX.Filesystem.RemoteStorageService] Failed to upload `/var/lib/3cxpbx/Instance1/Data/Ivr/Voicemail/Extensions/246/vmail_xxxxxxxxx.wav` -> `_3CX.Filesystem.AmazonS3.S3Folder/`, Unable to write data to the transport connection: Connection timed out.
at Amazon.S3.Internal.AmazonS3ResponseHandler.InvokeAsync[T](IExecutionContext executionContext)
at Amazon.S3.Internal.AmazonS3ExceptionHandler.InvokeAsync[T](IExecutionContext executionContext)
Syedx91
