Azure - separate each customers into Resource Groups
teckdan
Please separate every single customer created in Azure into its own Resource Group.
I won't have to mess with trying to separate resources after PBX Express has done its job.
PBX Express is being retired. Simply deploy from Azure marketplace to individual resource groups and you are all set.
Wondering why there's no mention on PBX Express... :confused:
Have you tried installing from the marketplace? nightmare after vm created... can't reach port 5015.
I did it a few months ago, didn't have any major issues. You have full control to adjust azure firewall. I think the only (minor) issue I had was that the version was older than the current release so I had to do a basic pbx creation, upgrade and restore the latest backup.
  1. Note: Due to a restriction of Azure on waagent and cloud-init on marketplace images, the swap file must be created manually after creation of the machine. SSH to your machine and proceed as explained here.
it says connection refused on port 5015.
Instruction states:
Copy the “Public IPv4 address”of your new instance and open it in a browser with port 5015, e.g.
http://public_ip:5015
I just found out that the /etc/3cxpbx dir was not created and no 3cx is installed.
mazet
