Back up without FQDN &licemse information
Yilmaz
SOHO User
I’m on v20
How do you take a backup without licence and FQDN fetails
Also how to upload that file in AWS lightsail
ive managed to login to my instance via file zilla however unable to to get access to the 3cx folder to access the backup folders
In v20 it is not possible. You can download your backups from within the admin page.
it seems to me it was a possible way to do so : (not sure if it's always working, but you can try )
SSH into PBX
cd /var/lib/3cxpbx/Instance1/Data/Backups/
sudo -u phonesystem /usr/sbin/3CXBackupCmd --options=MIN --file=pbx_min_bak.zip
3CX Backup command line tool.
To select options in the backup use the below strings comma separated,
example: --options=LIC,FQDN which will take a backup with License and FQDN only.
CH - includes CallHistory
LIC - includes your license information
FQDN - includes FQDN
PROMPTS - includes Prompts
FW - includes Firmware
REC - includes Recordings
VM - includes VoiceMails
MIN - minimal backup (backup only PhoneSystem configuration
--pwd=VALUE Specify the --pwd parameter to set a password to encrypt the backup
I can download but howto
Upload via SFTP as I can’t get access to the 3cx folder
SSH into PBX
I’m using FileZilla and can’t get access to the 3cx folder
If you use WinSCP you can select the Shell Sudo su
im not on windows i am using a Mac, Im looking for alternatives
It may be easier to put your backup on an external storage, and connect the PBX via SFTP to this drive to restore your backup.
Reactions: GregG_3CX
What is the goal? AFAIK one cannot restore a backup without a license and FQDN...
That is basically correct. But you can change the backup, e.g. change the license, get a new FQDN or use your own FQDN and certificate and then restore the backup. There are several options. As you say, it depends on what the goal is.
we have a license expiring the company has downgraded so they wont need a 16SIM any longer only 4. We dont want want to start from scratch as they would loose any saved data. They also changed business names so we could use this if someone has an answer to change out their key and change thier FQDN.
Contact customer service
https://www.3cx.com/contact/
Make sure to choose 'Licensing' and have your license key ready. :)
