Solved Backup Failing - Entries cannot be created while previously created entries are still open
MCCDCHS
Saving to Local Storage. /var/lib/3cxpbx/Instance1/Data/Backups
Can Manually Create a backup
Has been happening ever since install of V18.3
Can restart the system, and it works until it hits 3 backups and then this happens. (3 is the cycle we have it set to keep)
I assume it cant delete the old backup and fails at that?
Is there a repair command I can run?
Your 3CX backup failed due to the following reason(s): System.Exception: System.IO.IOException: Entries cannot be created while previously created entries are still open. at System.IO.Compression.ZipArchive.AcquireArchiveStream(ZipArchiveEntry entry) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName, CompressionLevel compressionLevel) at System.IO.Compression.ZipArchive.DoCreateEntry(String entryName, Nullable`1 compressionLevel) at _3cxNetBackupAndRestore._3cxBackup.CreateEntry(String name) at _3cxNetBackupAndRestore._3cxBackup.ZipFile(String dst, IFile src) at _3cxNetBackupAndRestore.BackupTasks.BaseFilesTask.BackupFiles() System.IO.IOException: Entries cannot be created while previously created entries are still open. at System.IO.Compression.ZipArchive.AcquireArchiveStream(ZipArchiveEntry entry) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName, CompressionLevel compressionLevel) at System.IO.Compression.ZipArchive.DoCreateEntry(String entryName, Nullable`1 compressionLevel) at _3cxNetBackupAndRestore._3cxBackup.CreateEntry(String name) at _3cxNetBackupAndRestore._3cxBackup.ZipFile(String dst, IFile src) at _3cxNetBackupAndRestore.BackupTasks.BaseFilesTask.BackupFiles() System.IO.IOException: No space left on device at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) at System.IO.FileStream.FlushWriteBuffer() at System.IO.FileStream.Dispose(Boolean disposing) at System.IO.Stream.Close() at System.IO.Compression.ZipArchive.CloseStreams() at System.IO.Compression.ZipArchive.Dispose(Boolean disposing) at System.IO.Compression.ZipArchive.Dispose() at _3cxNetBackupAndRestore._3cxBackup.FinishingTask() at _3cxBackupRestoreImpl.BackupRestoreUtils.Backup(IFilesystem filesystem, String instanceId, String cfgPath, String dbConnectionString, BackupConfig options, String fullpathFilename, Boolean sendEmail) at BackupRestoreSchedule.BackupJob.Execute(IJobExecutionContext context)
Scheduled Backup ID: 50022 04/14/2022 10:01:43 PM
I see a "No space left on device" in there, can you make sure there's enough diskspace? What's the currently available space and what are your backup sizes?
Reactions: MCCDCHS
OMG, I didnt even notice. Yeah the drives full. hahaha! Darn VoiceMails.
Reactions: ChrisC_3CX
No worries! As long as it was a quick fix!;)
Let us know if you need anything else!
