Backup & Restore your PBX with the PBX Express Tool
StefanW
3CX’s PBX Express tool can restore backups of existing installations. This enables customers to:
  • Move from an on-premise installation to the cloud
  • Change cloud provider
  • Use it as a disaster recovery method.
The only requirement is a backup of the current installation, with the options “Include Lic...
Is this still valid? How do I access pbxexpress? Cannot find the link "Restore from Backup". https://pbxexpress.3cx.com just leads you to the login page.....
pbxexpress is now just 3cx
You go into your customer portal, then keys, then click on more next to your key.
You can choose to self host and this will start the wizard.
Once done and the system is deployed, you can optionally set your backup destination to point to your ftp or bucket, and then restore a backup directly from there.
Thanks for your replies. A common problem is outdated posts and docos. Thanks, achieved what I needed using 3CX (formerly Express) in the 3CX portal by just running the wizard and restoring the backup.
jb_erp
