Solved Backups to SharePoint
RoyJ
New User
I am trying to configure backups to SharePoint according to https://www.3cx.com/docs/manual/sharepoint/.
However, when I go to Admin Console > Backup > Location > Select SharePoint as Location type, it will not let me enter the location. If I click on the button to the right, then another box that looks like it should have a list pops up blank.
Any assistance would be greatly appreciated.
Thank you,
The popup would show folders in the Documents library of the main root SharePoint site. Not any "team" site or subsite.
If you don't see any, that's because there's no folders created in there.
You need to set up 365 integration first also.
Reactions: RoyJ and Evolute IT
Thank you so much, this information helped and I was able to configure it successfully. :)
The most important is to identify the root Sharepoint site in order to proceed with correct location.
Glad to know this is resolved. ;)
No members online now.
RJenkinsROCK
