Solved Bad sound quality
Faulhaber GmbH
Hi there,
I am currently setting up my first 3CX and it's working really good so far. There is only one thing that is not so good: the overall sound quality - even with internal calls. It sounds dull and muffled because there is almost no 'S' tones (treble is very low). On the other hand, bass is also a bit low, so all in all it sounds a bit strange.
We are testing with the 3CX softphones at this point.
3CX firewall check reports that everything is fine but this only checks on the WAN side, right?
Codec priority for internal calls is G722, G729, GSM, PCMU, PCMA, OPUS. Changing codec priority in the 3CX stettings doesn't change anything it seems... that's a bit weird.
Our network never had any issues (HP ProCurve switches with loop protection), no local firewalls.
Where could I start my search?
Thanks in advance,
Bruno
What is your setup ?
3CX hosted locally or in the cloud
What phones are you using ? How are the phones provisioned - local , sbc ot stun.
Oh yes, I forgot to mention: 3CX is running on premise as a HyperV guest (Windows Server 2016)
Currently we are only testing with the 3CX softphones, locally provisioned. I also tested with one of our Auerswald phones but these are not supported anyways.
The interesting thing is, that we experience these sound issues with internal calls. So it can't be a router or WAN issue.
I didn't consider that document when setting up the virtual guest but it's all fine:
  • drivers are up to date
  • VMq is disabled
  • time sync is pointing to our domain controller and not to the hyperv host itself - I guess that shouldnt be a problem
Try using PCMU or PCMA (depending on region) as your first (only, as a test) choice Codec. See if this makes a difference. What is your Providers Codec of choice? That should govern what you use internally unless there is some reason to use low bit-rate Codecs. If you don't, you will probably have transcoding on external calls, which can cause audio issues in many cases.
Hello @Faulhaber GmbH
Make sure that the internal codecs of the PBX are also set to the same priority. You can do so by navigating to Settings / General / Codec Priority for Local/Internal Calls.
It may be a case of transcribing if PBX delivers audio is enabled on Recording is enabled under extension settings.
Are you sure you followed the point about using a gen1 hyperv install? If you use gen2 we have seen poor audio quality issues.
Thanks a lot for all your feedback. It took 4 persons to find the source of our bad sound issue:
  • softphone to softphone: bad quality - that's what we were testing
  • softphone to webclient: bad quality - that was our second test
  • webclient to webclient: good quality - we did not check that one
  • webclient to softphone: good quality - interesting because quality is bad when the softphone calls
Because we rely on TAPI and because headsets are easier to install when using softphones, we investigated further... and further. Turned out that it seems it was our mistake: we were always changing codec priorities in the general 3CX settings and suprisingly it didnt make a difference. Well, we did not know, that every phone has its own codec settings. Primary codec was GSM. As soon as we added OPUS as primary codec for each extension the sound quality changed from good to phantastic. I'm not sure if this is documented somewhere - at least I can't remember having read about this.
Again, thank you for your assistance. This forum really turns the 3CX into such a good system :D
Glad to see the issue has been resolved and thank you for your kind feedback.
SpacetelSupport
