Bespoke Trunk Provider Template
shedster99
I've taken the default trunk template and edited it to allow for specific P-AssertedID settings along with some RPID stuff.
If I drop it in the required folder it shows up fine and I can use it as a template, all good, works a treat...however...
I need this to form part of our automated deployment as part of our Linux CLOUD-INIT scripts.
Prob I have is if I get the script to create the required folder, GET the file which is all good, 3CX fails to install. I'm 99% sure it's a permission thing on the 3CX folder ie it's owned by ROOT and not PHONESYSTEM.
Anyone any ideas how I get these specific settings into an automated config via an alternative to the above or included in the SETUPCONFIG.XML file ?
TIA.
PS, I have tried to CHOWN the folder and subfolders to 777, download the file, install 3CX then CHOWN the folders back to PHONESYSTEM but 3CX still doesn't install :-(
WagnerFT
