Best paging combo you've used yet?
ElementalWindX
What is the best paging setup you've done so far?
SNOM PA1?
Algo 8180?
Something else?
Wondering which one is the easiest and most reliable to setup with a 3cx setup.
I'm working with a client who has a Viking PA-2A at the moment.
Thanks!
Ive used the Fanvil PA2 twice with no problems. If you go with a support one you'll have no trouble.
Reactions: ElementalWindX
CyberDATA Sip Paging Adapter is pretty much plug and play and their support is amazing (but you won't need it! ;))
Reactions: Naveen | Cal4care
RemyDijke
