Best way to bulk change DIDs for 70 users.
SBNGT
Whats the best way to change DIDs for 70 users from a temporary number provided by a new carrier to the actual numbers post port from the old carrier?
I tried to export from extensions page, change the DID number and reimport but the system gave me an error.
Import complete. Warning: not all rows were imported.
The list below contains the rows that were not imported with the column header that caused the import to fail:
2 (Number)
Thanks in advance,
"Number" refers to EXT # and because they already exist you cannot overwrite.
You could delete and import but you'll lose EXT set up along with VMs and such which is probably a lot less hassle than updating them manually.
How about exporting the Inbound Rules and modifying. Then importing...
Thanks for the update. Not ideal but only a hours work, I guess.
3K8iMGWviZ
