Dear, I would like a better integration of Snom D865 devices in 3Cx software. The following are the features: - Choice of and volume of the incoming ring signal - Reduction of the call screen, so that the function keys on the side remain visible and usable. - Dim the screen brightness for a device in the bedroom. - Possibility of multiple pages and thus allow multiple functions for the function keys on the side. (next and previous page) - See photos of the called party or caller (if loaded) All these features are usable on the device, but are overruled by the 3cx software. Thank you for paying attention to this report. Kind regards,
Hi Tom,
I used Google translate, please excuse me if there are any mistakes.
Firstly, please note that on StartUP there are less features and options because it is a simpler product than the full dedicated 3CX server. Some of the customizations you want can already be done when using a dedicated 3CX system.
So for D862 / D865 models on a dedicated 3CX server see the following:
- Ringtone: Can be controlled from 3CX already for internal calls, and queue calls. External calls is hardcoded, we override this and there are no plans to change this but you can use a custom template if you wish.
- Ringing Volume: Not controlled by 3CX - not planned to be added
- Screen Brightness: This is already available, but only in the options you see below
- Active calls screen size hiding the BLFs: This is a Snom decision, we don't control this - contact Snom for more details
- BLF Pagination: We already informed Snom and they will address this in the next firmware release
- Contact Photos: We do not provision or override this.
