Bitrix24 - 3CX - CRM Integration
TobiasE
New User
Hello 3CX team,
We have a Bitrix24 cloud version and would like to connect it to a 3CX system via. Connect WebHook.
The connection also seems to work. or calls are at least displayed in the Bitrix log.
However, when a call is received, no window only opens to accept the calls. Outgoing calls are also not possible.
Can you help us? VG
bBitrix scheint den Anruf zu erkennen, leitet auch weiter. Ohne // würde es aus funktionieren
Phone calls are handled from the 3CX client, not from Bitrix. From your screenshot I can see that you're using the 3CX Desktop app, you need to answer the call from there. The desktop app will launch the contact record in Bitrix, by launching a new browser tab when it receives a call. If this is not happening, please check the popup blocker from the browser, because I can see the matched contact in the 3CX Desktop app.
Regarding outbound calls, you need to turn off any telephony provider in Bitrix, so phone numbers are rendered as "tel:" URIs, and the Bitrix in-built phone system is not used.
costionofrei
