Black listed from all IP's
Mitch Fairbanks
I am in a bit of a pickle. It all started when I received "Amazon EC2 Instance Retirement" email. I had updated everything once before and it went fine. This time though I'm not sure how it went so wrong. I keep entering the same password I always have (Copied and pasted from email). but it just didnt work. Unfortunately i have tried from all my different IP's and it appears im blacklisted on all of them. How do I get un blacklisted?
Hi @Mitch Fairbanks,
We have a KB to allow you access to your instance provided you still have SSH / Remote Desktop access
Which brings me to my next problem. My private key information is on a computer that is no longer used. At this point in time I am fine with just rebuilding from scratch. Do I just release my 3cx instance on AWS and create a new 3cx account? Will the ip address still be blocked? Can you please advise?
Ok found my .pem key and converted it to .ppk. I can log on with putty just fine after i type admin. But i can not access 127.0.0.1:5000 as in the instructions. I tried changing ports from 45000 but still no luck. Im almost there. Is there any other advice?
When you follow the tutorial above, you should be attempting to connect to 127.0.0.1:45000 not 5000. Are you stuck or did you resolve this?
Reactions: NickD_3CX
megalmazan
