Blacklist Import .json File
Boschko
Intermediate Cert.
Does anyone have a template for ip blacklisting a slue of IP ranges? Id like to simply be able to import a json file with said ip's and not have to do them one by one. example IP's:
36.0.0.0/6​
41.0.0.0/8​
42.0.0.0/7​
44.0.0.0/8​
46.0.0.0/8​
so whats the import json file format?
Hello @Boschko
Set the first range manually into the PBX and then export it. Open the json file and see the format. You can then add as many as you want. It should look like this:
10923
Reactions: Boschko
RicoDinero
