Solved BLF button copy to existing sets
STI-David
Gold Partner
Client has 3CX dedicated Pro hosted by 3CX with Yealink T54W sets
How do you copy BLF buttons from existing user to other existing sets.
The COPY option under Users which give options on what to copy over, only works for non-existent sets.
Hope there's an easy way to do this, rather than going one by one.
Thank you,
David
SOLVED
Found my answer in the forum.
"Select all the extensions you need to add the key to, click edit, go to the BLF tab, and add the key to an unassigned button"
Reactions: Alejandro_3CX
