- Joined
- Feb 9, 2018
- Messages
- 4
- Reaction score
- 1
I have two sites, each with their own 3CX PBX, and they are connected via VPN tunnel and over that tunnel they are connected via Master/Slave bridge to one another. Site 1 is using extensions 1xxx and site two using extensions 2xxx. Presence is set to push/pull all extensions from both sides and there are no errors being reported, firewall checker passes, etc.. Calls can be made and transferred across the bridge without a problem. I've even used the call flow designer to direct calls appropriately between the sites. But, what I can't seem to get to work is setting up BLF keys to see extensions at the remote site. When I'm in the web management interface and configure a phone/extension... the BLF dropdown options are limited to only local extensions. None of the remote extensions are available for selection. I can set up custom speed dial to just blindly reach out to that extension... but not with a BLF key. Is this not possible??? What's the point of exchanging extension presence if not for use in BLF keys?
I feel like I must be missing something easy. Any help would be most appreciated.
