BLF=SPEED DIAL
ArtoSkogman
Hi!
After upgrading to v20 blfs stopped working. Now they work only as speed dials. Customer has SBC working. Phones are Grandstream GXP2135s and GRP261xxs, total 10 pcs.
Phones have latest 3CX approved firmwares.Has anybody any ideas how to fix this issue with v20? With V18 blfs worked fine.
Check the provisioning links are correct on the phones. Factory reset one to test.
Done that. Did not change anything.
done both?
Yes, with all phones. Also tested with both 3CX and Grandstream blf setting with all combinations. Only speed dial works.
Can you try refreshing your license in the dashboard?
Dashboard->license details, there I can/did refreshing.
parik24pro
