Blind / Attended Transfer
teagle
Intermediate Cert.
I have had a couple of instances where our Fanvil phones have re-provisioned themselves and lost all the users BLF's that they have set on the phone. I have been told that if I programme them in the 3CX System Console, the BLF's will remain and won't have to be reprogrammed. ( Is that the case? )
However, it seems that within the console, there are quite a few options that aren't present compared to the phone, including the option to 'Blind Transfer' ( BLF/BXAFE ) or 'Attended Transfer' ( BLX/AXFER ) - I have programmed the users phones in the Console only, but they are saying that when they transfer calls they are all 'Blind Transfers'. I have changed the setting 'Select transfer method used (Blind or Attended) when you press a DSS key' in the 'Provisoning tab' to 'Attended / Consultative Transfer' and rebooted the phone, but they are still saying the issue remains.. Never had the issue when the numbers were set up on the phones rather than in the console? Do the BLF settings in the console over-rule the ones on the phones?
Thanks in advance..
Hi Teagle,
3CX provisioning includes BLFs and the option of attended/blind transfer.
So if you make any manual changes to the phones, the daily auto-provisioning will definitely overwrite them. If you change it from within 3CX, you will no longer have this issue. The phone settings are out of sync now - Please factory reset the phone and reprovision it once you setup the extension setting like you want them:
- Set your BLFs from the extension's BLF tab
- Change the transfer behavior of the phone BLF buttons from here
SupportRock
