Solved Brand new created extension shows registered right away ...?
BABALUCHA
Hello Everyone
Thanks for stopping by and contributing to this. It is weird that i created an extension # 50101 and as soon as i created it ,the status shows green light as registered and shows up on "People" as well. Could anyone shine some light on this as it is beyond my understanding.
This is what i have special done for this extension is :
1 Ring my mobile simultaneously
2 PBX Delivers Audio
And also customer does have an app allready registered which is with another loosing carrier which i can't name here. I m not sure if that has anything to do with this.
Thanks again in advance.
Hello Everyone i have found out that if the option for USER >Forwarding Rules>Ring my mobile simultaneously is ENABLED (Checked) than the extension will show the GREEN as REGISTERED. And as soon as i DISABLE that it will show UNREGISTERED (RED). Thanks.
That is indeed the case, "Ring my mobile simultaneously" will forcibly register the extension regardless of whether it is actually registered on an IP Phone or softphone.
WAFI
