Bridge between 3cx and UTM 6102
softgroup
Trainee Partner
I'm new one 3cx user and I need little help with make bridge between 3cx and Grandstream utm6102
I create master bridge on 3CX where default virtual id is 10000. After that I create register sip trunk on Grandstream UTM. I see that is registered.
also I create outbound rule which say that If I call from 3cx to 805 extension then should be choose bridge to grandstream,
So,
First problem - if I call from 3cx from extension 124 to 805 (extension on UTM) then it answer but id number is 10000 (virtual id number). I tried to change many settings also on 3cx in tab outbound parameters and also on UTM. But without success.
Second problem - On utm I create outbound rule and I made a call from 805 to 124. I see on 3cx that some traffic but without success.
Code:
04/02/2021 11:43:26 AM - [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 77.65.x.x:7062 tid=Pj69233143-8820-49b5-abe1-4cc06cfe0125 Call-ID=00d505ce-e701-4196-9662-b3449c107136:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 77.65.x.x:7062;rport=7062;branch=z9hG4bKPj69233143-8820-49b5-abe1-4cc06cfe0125
Max-Forwards: 70
Contact: "Serwerownia" <sip:[email protected]:7062>
To: <sip:[email protected]:5060>
From: "Serwerownia" <sip:[email protected]>;tag=8f85c1f4-da10-4db1-9924-bab5c0a58591
Call-ID: 00d505ce-e701-4196-9662-b3449c107136
CSeq: 17288 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: OPTIONS, INFO, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, REFER, MESSAGE, REGISTER
Content-Type: application/sdp
Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",nonce="414d53596066e73e08:34b32f674488551e08743350e07ebb0d",uri="sip:[email protected]",response="1085db81631b59e888c30acd3c6bc00e",algorithm=MD5
Supported: 100rel, timer, replaces, norefersub
User-Agent: Grandstream UCM6102V1.6A 1.0.18.18
P-Asserted-Identity: "Serwerownia" <sip:[email protected]>
Remote-Party-ID: "Serwerownia" <sip:[email protected]>;privacy=off;screen=no
X-Grandstream-Transport: trunk
Content-Length: 360
Please help me with this problem. Maybe someone have solution for this bridge. I need have bridge between 3cx and utm and all extensions between should make a call.
Thanks.
Many people tried this. Search the forums, you'll find a few.
The caller ID problem was never fixed. We all tried.
The call issue should work, but check headers and RPID and PAI on the UCM. Those are tricky to configure.
Here's the best route: go full 3CX or full UCM.
awan05
