Solved Bridge call as intercom, while not setup as intercom
saint_
Forum User
Hi all
I have a good one.
2 PBX using bridge connection. Both are on version 16.0.0.1581
PBX A - Master Bridge - Virtual extension 10001, outbound prefix ***
PBX B, Slave bridge - Virtual extension 10001, outbound prefix ***
On each bridge the Paging dial code is *64
PBX A has only 1 Paging group with local extensions
PBX B has one ring group, and one paging group with local extensions
Both PBX have an outbound rule *** going respectively to the remote PBX (PBXA=3 digits extension, PBXB=2 digits extension)
The issue is that.. when PBX B calls ***100 for example , the communication goes through as intercom
If PBXA calls ***22, the 22 has to pickup the phone
I don't get it.
Any hint appreciated.
A factory reset of the phone answering in intercom fixed it. :/
devo.it
