Bridge sip trunk between STD & PRO license
MrUn1x
Hello
I had a customer who requested to make a sip trunk between 2 3cx servers , one of the server is STD License and the other one is PRO License
and they want to make calls between this 2 servers
i had setup the trunk and its up but i had issue between calls from server to the other .
so how can i get around it ?
Std don't have bridge. So I guess you used a regular SIP trunk?
Yes i did so , calls is up now but the virutal ext is the caller id
so when its route calls to STD , calls go to default ext configured on sip trunk
I would recommend upgrading the STD license to PRO to create a bridge between the 2 systems to save your self a lot of manual configuration and guess work.
There is a lot of configuration involved to set it up using a trunk depending also of the size of the system and you will need to do extra work every time a new extension is added or deleted.
lastshadow
