Bug? - Holiday programming
Phlobot
When setting up a holiday for a range of days, if you set a time in the single day parameter and then change to range of days, the time selection disappears as one might expect.
However it still apples the previously specified time to this rule, for each of the selected days. Shouldn't this be configurable for the range of days in case the hours are simply modified for those days? Otherwise the hours selected in the single day should be ignored when changing to day range.
Just thought the behavior was odd and unintuitive, or perhaps unintended. It's easily reproduced using the steps above.image_2020_12_24T14_51_40_728Z.png
If this is the intended behavior, keeping the time selection available would make this more intuitive.
I believe this is just s visual issue. When you select a range of days, it applies for the whole day. Even though the time is displayed, it doesn't apply.
fransisco
