Solved Bulk Change of BLF buttons
echotech
Is there still no way in V20 to do a bulk change of the BLF keys for multiple extensions to apply across multiple handsets? I feel like I'm in the dark ages of having to go through and make changes individually for each extension. All the extensions are already set up I don't want to have to delete them and then recreate from a template extension. What am I missing here?
Thanks all.
You can step into the light as this is an option already with v20.
  1. In the Extensions or Phones list, check the boxes next to the extensions you want to update.
  2. Click Edit.
  3. Under the BLF settings, if all selected extensions share identical BLFs, you’ll see them listed—otherwise blanks appear where they differ.
  4. Adjust the keys as needed and hit Save.
  5. The phones will reprovision automatically with the updated layout.
Brilliant. Thankyou. I have seen the light.
