Bulk edit extensions (if over 100)
LewisBurgess
I would like to bulk edit some extensions. If I click the 'select all' box at the top of the extension list then click edit, it errors as I've selected 567 extensions (the max is 100).
I tried filtering the list by typing the first couple of numbers (e.g. 22 for 2200-2299) but then the select all box is greyed out. It really ought to be possible to select all on a filter.
How is it possible to bulk edit without having to manually select each one, edit, repeat 6 times. That's around 600 clicks - madness!
Is there another way I can bulk edit? I would like to bulk enable Push notifications for smart phones (which it's possible to do, but not relishing having to select 100 at a time manually).
I hope nobody suggests I create a thread for 'suggestion improvements for voting'. Shouldn't be necessary to have a vote on a poor GUI issue for large installations!
Thanks.
hi,
we have the same problem
same problem here
Lengo
