Bypass PIN Protect for some numbers
yetopen
Hi.
Is it possible to configure some external numbers to bypass PIN protection? For example we'd like to allow calling local emergency numbers without entering the pin.
While writing I thought this could be achievable by configuring an internal extension that would forward to an external number. Will it work?
I think you will find, if the numbers are entered under Settings -> Emergency Numbers will not require a pin.
Is this confirmed or I need to check?
You will definitely want to do testing when it involves emergency numbers, you want to know that calls will work. Just be sure to wait until they answer, and explain you are testing, or you may have the police knocking on your door.
Will adding your exclusions under emergency numbers cause 3CX to send out emergency notifications? I do not think we want that.
Vera Lea Kristensen Raage
