C# Expressions in template
railkos
[[CallStartTimeLocal].AddHours([HoursFix]).ToString("yyyy-MM-dd HH:mm:ss.fff")]
This expression throws an error System.NullReferenceException at TcxLexicalParser.LexEvaluator.InstanceFunction
[[CallStartTimeLocal].AddHours(1).ToString("yyyy-MM-dd HH:mm:ss.fff")] works nomally
Any ideas how to fix, or another way to add custom time from "Parameters"?
Hello @railkos,
Using the parameter there will not work due to the way the expression is evaluated.
If you have only a few options, for example 1, 2 and 3, then maybe you can use conditionals. For example, to send a value using conditionals you would do something like this:
Instead of:
XML:
<Value Key="call_date_time">[[CallStartTimeLocal].AddHours([HoursFix]).ToString("yyyy-MM-dd HH:mm:ss.fff")]</Value>
You should use:
XML:
<Value Key="call_date_time" If="[HoursFix]==1">[[CallStartTimeLocal].AddHours(1).ToString("yyyy-MM-dd HH:mm:ss.fff")]</Value>
<Value Key="call_date_time" If="[HoursFix]==2">[[CallStartTimeLocal].AddHours(2).ToString("yyyy-MM-dd HH:mm:ss.fff")]</Value>
<Value Key="call_date_time" If="[HoursFix]==3">[[CallStartTimeLocal].AddHours(3).ToString("yyyy-MM-dd HH:mm:ss.fff")]</Value>
You can add 24 lines like that if you want, or just the values that you consider valid...
lastshadow
