C# Webclient authenticate for API access
Apereira
We are using V18, and I wanted to be able to access the API via webclient.
When I try to use simple authentication I get returned with a 401 error, how do I authenticate?
I know a few endpoints, but not sure about all of them, is there any documentation?
Regards,
Thank your for this, I was looking for c# code but provably can try to read PHP and convert :)
3CX Documentation on the CallControl API was pulled a few years ago. That being said, the CallControl API is used by 3CX internal systems and while you are encouraged to not use it, it's unsupported, etc - it's still out there and might be of use to you.
Yes, I've known about it on previous versions.
I think one of the limitations was that it does not respond to external queries.
Thanks for the link, cause I could not find it anywhere.
NathanMitchell
