Call data records tool
David_O
Hello
I am currently writing a python app to save cdr in data base and make some reporting in Grafana, but i have a little problem , as i am a développer i do not have a 3cx working to create cdr , if someone Can send me some data without sensitive informations , i would be.nice
The app URL
https://github.com/dorel14/3CxCdrTcpServer
Thx
Just install a cloud 3CX VM with a temporary trunk provider to generate some data? Then use that to send the data to your app.
Thx for you suggestions , but i will like having a lot of data , an other part if my soft would be to make some prédiction from old data , and prepare proposition of number of agent needed to fit these prédictions
No one will send you data with personal information in it.
Ok , do you know somekind of very cheap trunk provider with no engagement for my testing ?
Thx
StevenWillems
