Call details in CC API
Trestill
Platinum Distributor
another trouble for me is getting call details.
The data I need is:
* direction (inbound/outbound)
* state of the call (ringing, talking, hold, etc.)
* caller number
* callee number
* queue number (if this is inbound call from queue)
Code:
ActiveConnection[] conn = PhoneSystem.Root.GetDNByNumber(id).GetActiveConnections();
string result = string.Concat("CallID: ", conn[0].CallID, " ; OriginatedBy: ", conn[0].OriginatedBy, " ; status: ", conn[0].Status, " ; OnBehalfOf: ", conn[0].OnBehalfOf, " , DialedNumber: ", conn[0].DialedNumber);
id is extension number which interest me. And what I get is:
["CallID: 272 ; OriginatedBy: ; status: Ringing ; OnBehalfOf: , DialedNumber: "]
Any suggestions what I do wrong here? And how to get info from AttachedData (is there anything usefull) ?
Regards,
Trestill
You can't get call "history" from the Call Control API. You can, however, monitor events in real-time. If you want historical information, I suggest you look at the CDF text files 3CX can generate after the call is complete. This will have most of the information you are looking for.
costionofrei
