I'm not sure how much I would use the CFD, but I for sur would like to try it. I don't think it would be too crazy, probably process payments, send reminders and such.@DavidM84 on our side we run this on 4CPU 8G RAM buuuut, in your case i dont know how heavily you want to user CFD so maybe you will need to go one step up.
But again, depends on the usage and the call flow routing on the system.
On any case though you can go with the plan for 4/8 and upgrade is only one button and 5 min downtime for DO.![]()
then yes go with the 4/8 as a startup and i think you will be good to go!! On any case a 5 min downtime to upgrade if needed is very easyis the basic droplet at $48/mo 4 cpus and 8gb and 160 SSD a good option then?
That's good to know. For now, if we move forward with 3CX, we'll stick to the hosted by 3CX Business Edition (pending approval), and then see how much the system is used, and in a few months see what we need to adjust.then yes go with the 4/8 as a startup and i think you will be good to go!! On any case a 5 min downtime to upgrade if needed is very easy![]()
CFD isn't supported on 3CX hostinghosted by 3CX
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
