Solved Call from Extension to Extension fails
Jkeeney
I have 20 Yealink t29g phones with the suggested 3cx firmware. The reception uses anYealink expansion module. Half of the extensions are remote connected using STUN. To contact a remote extension, reception picks up the handset and pushes the corresponding BLF. About half of the time, the BLF indicator light does not switch from green to red and no ringing occurs. If reception waits long enough, it goes to the dialed extension voicemail. Below are two logs; the first is unsuccessful and the second is successful. The logs diverge at
UNSUCCESSFUL
03/10/2020 1:47:01 PM - OnOffer from L:5533.1[Extn:100]
03/10/2020 1:47:01 PM - [CM505001]: Endpoint Extn:100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T29G 46.83.0.130 001565e5fd32] PBX contact: [sip:[email protected]:5060]
03/10/2020 1:47:01 PM - [CM500002]: Call(C:5533): Info on incoming INVITE from Extn:100:
SUCCESSFUL
03/10/2020 3:01:01 PM - OnOffer from L:5619.1[Extn:100]
03/10/2020 3:01:01 PM - [CM500002]: Call(C:5619): Info on incoming INVITE from Extn:100:
When you say ‘half of the extensions are remote’ , how many phones are at each location.
if you have multiply phones at the same location have you
1. Assigned different sip / rtp ports to each phone.
2. Given the phone a fixed up address (can be done via DHCP reservation)
3. Setup port forwarding on the firewall protecting the phones, to forward the correct sip and rtp ports to the correct phone.
use the search function, and you will many posts on stun setup
Wondering why the unsuccessful log has the additional entry the I formatted in bold. It seems that if the unsuccessful has that line and the successful doesn't, that line must provide some clue as to the problem.
Thanks everyone for your help. With the info provided I have been able to resolve.
Kayla Norris
