Call History not showing for User when picking up call using 'Call Pickup'
Neil @ CommsProvider
I am sure this is probably default behavior however. We have a customer who is on 3CX V18 On-Premise with Fanvil X4 handsets. When they are short staffed, users who aren't in the main call group are hearing the calls ring and dialing ** to pickup a ringing call. They are a solicitors so sometimes need to go back to the call in their history and call it back, however when they use call pickup they only see the action of dialing **, not the call they have been on. This is available within the call logs on the server, however they all don't have access to this and would ideally like to see it in their history.
Is there a way to do this? Or is this the default behavior and not much of a way round it? They are using queues so if it becomes a big issue we can get them logging in and out when they short staffed.
Many thanks
Neil
Hi kieferschild,
Thanks for the response! I had a look and they already all had the options turned on. I have for completeness disabled the options then re-enabled. I noticed that the originator of the thread was only having the issue on phones, and another thing our customer noted was they didn't have the same when people transferred calls in. I have had a look at the phone provisioning and we hadn't changed the transfer method to consult rather than blind. Not sure if it will make a difference but i have changed it for a few extensions and asked them to monitor.
Many thanks
Customer has been in touch and apparently neither of the above worked, still just showing **. Will have to pull some Fanvil's out and get them hooked up to our in-house system and see if i can get them to behave.
Silent_Guru
