Solved Call Log
kenttec
Hi Guys
Is there a way to delete the 3CX call history as I have a customer who wants to remove all call history from a certain date or all and start a fresh?
In version 15.5
Settings -> Call Reports -> Settings Tab , you will see option to 'Clear Call Logs'
Please note that this will permanently delete the call logs and there is no option to recover them once you delete them.
It sounds like your customer doesn't care about the history, but just to provide another option, you could use our 3CX Exporter tool to save the information in a SQL database, then truncate the data. That way you reduce the load on your 3CX server, while maintaining the information for historical purposes (year over year custom reports for example).
Thanks for the help!!
All sorted now
Glad to see the issue has been resolved
