Call Logs and Reports cannot be filtered by a DID when it has an inbound rule to a Call Flow App
bouncy
So, a good example of this would be wanting to see call logs for one of my DID's which is routed via an inbound rule to a call flow app. If i try to filter my call logs by the to field, i can select a range of options, including numbers. If i try to search for the inbound did routed to the Call flow app, no results are found. If i look generally in the logs, the inbound did doesn't show, but the call flow app does that is receiving the calls does. Nowhere can i see a filter rule that allows me to filter by call flow app. The same is true for all the call reports - report.
