Call pops on internal calls
JetWave
Hi, I tried searching through existing posts and I couldn't find anything so I'm sorry if this is answered elsewhere. I have a potential client that did a horrible job with their phone number formatting in Salesforce. They have about 8 different ways their phone numbers are loaded, and I've only gotten call pops to work on exact match (yes, I tried last 6 or 7 digits but it won't match all types). And the only way I got this working was to change the in the 3CX webclient to "Auto launch a custom contact URL using variables".
I'm getting great contact matching with this method as I'm using a Salesforce Classic global search string with parameter %CallerNumber% and its notifying when connected.
My only problem now is this is trying to call pop on even internal calls. Is this normal behavior? Or a product of my switching the method to auto-launch a custom contact URL using variables?
Thanks in advance
That's to be expected with using the custom URL. You can, however, create your own CRM template to program your own behavior.
Okay, thank you, that's what I was afraid of. Seems my workaround will have a negative side-effect. I'm not familiar enough with programmatic language or XML to make my own template, I'll have to look around externally to see who could do this.
DM us.
xyloite_admin
