Call processing script to divert to a DN when calling 9
Gilles (Transacom)
Gold Partner
Is there an example call processing script that shows how to divert to a DN (for exemple ring group 8101) when an extension dials 9?
Trying to create this script for a hotel configuration where rooms dial 9 to reach the reception.
Thanks,
Gilles
Another option is: use a dummy extension, have all incoming internal calls forwarded to the call group 8101, give the extension the SIP ID 9 and activate direct SIP calls ( Admin / System / Options / Allow Direct SIP calling).
Or:
C#:
#nullable disable
using CallFlow;
using System;
using System.IO;
using System.Threading.Tasks;
namespace dummy
    public class RouteTo8101: ScriptBase<RouteTo8101>
        // process incoming call
        public override async Task<bool> StartAsync()
            await MyCall.AssureMedia().ContinueWith(
                    x=>{
                        return MyCall.RouteTo("8101", null, 60);
                        ).Unwrap();
            return true;
Reactions: Gilles (Transacom)
Or write a new CFD App with only one transfer (to 8101) block, build it, expand the zip, copy the much larger .cs file content and save it as a new call processing script.
There are definitely other options. Another thing that comes to mind is changing the route/dial plan on the phone using a template.
Or:
C#:
#nullable disable
using CallFlow;
using System;
using System.IO;
namespace dummy
                    x=>{
                        ).Unwrap();
            return true;
Thanks !
But this works everytime everywhere. Is that really what you want?
Well, since I am creating a call processing script that runs "When a user dials a code" with dial code 9, it works just fine!
The final script will be a bit more complex because the effective destination will depend on the department from which it was dialed.
I would do and expect something like that too :)
I just tried this on V18. Dial codes must start with an asterisk ( * ). While that is not a significant requirement, I will mention that you can make single-digit extensions (9 for example) using the 3CX Call Control API. We have been doing this for years without issue.
Reactions: fxbastler
Yes, that's right, nice to know. But that wasn't the question ;) It's a v20.
tom.walker@blackcountryra
