Call Quality Issue
RoyJ
New User
Hi everyone,
I use Flowroute for SIP Trunk, and my system is hosted by 3CX.
I'm trying to troubleshoot some call quality issues and want to run a packet capture, but I can't find this option in my 3CX Hosted Instance. Could someone please guide me on how to start the capture?
I can hear the other party fine with no issues, but I'm told that I cut in and out. I confirmed this by listening to the call recordings and performing an Echo test using an echo test service.
To further troubleshoot, I tested with another VOIP provider outside the PBX (Google Voice) and found that the call quality issue disappeared.
Thanks!
If you are running a V20 you can enable "Monitor Connection Quality" from your extension as per screenshot 1713833919513.png
Reactions: OlegR_3CX and RoyJ
If you are running a V20 you can enable "Monitor Connection Quality" from your extension as per screenshot View attachment 41039
Thank you! I did not see the option on the desktop softphone, so I enabled it via the web app. Where does this information go to? Flowroute is requesting it.
You will see the reports in your call history next to each call
@MiraG_3CX
Thank you for this!
I actually just did a test call from the web app and the call quality is fine, no issues. It seems to only be with the Windows Desktop app.
However, I did enable monitoring for one day.
If you’re on v20, be aware the Desktop App is officially removed. It may continue to work. There is the web client, PWA, and new Microsoft Store app.
Reactions: RoyJ and OlegR_3CX
Thank you for this. I am indeed using the 3CX app from the Microsoft Store.
ARKC
