Call Queue Recording (Bug?)
Andreas Olenitzack
Intermediate Cert.
I found this manual für Queue Recording. But in the Version "16.0.3.676 " multiple calls option doesn´t work.
When a second call cames to the Extension, i got only the VoiceMail and the forward rule to the mobile number doesn´t work.
What i have to do, that it should work?
Shadragon, do as following:
  1. Create a virtual extension
  2. In the field Mobile Number enter your Queue Number
  3. In forward rule check Ring my mobile simultaneously
  4. in Options: Enable on this virtual extension call recording
  5. Don't forget to check Accept multiple calls
You shoud record all your Queue even if no agent login.
Quelle: https://www.3cx.com/community/threads/call-queue-recording.54829/
Call recording with queue settings is bugged and has been since at least April 2019. I've got an instance running 16.0.493 with a call queue that has recording enabled and set to allow opt-out. Incoming calls do not get recorded unless the agent has always record turned on at the extension level.
Unfortunately, there doesn't seem to be a good way of reporting bugs with 3CX unless you want to purchase support cases.
https://www.3cx.com/community/threads/how-to-record-all-calls-in-a-queue-in-v16.65158/
natedog
