Call queue report with visible numbers
alexis41818544158
Platinum Partner
Good morning,
Is there the possibility of sending a daily report via email which also includes the telephone numbers of missed calls in a queue? In the reports option there is a similar function but I don't think it also shows phone numbers.
Thanks for your help
You can do a call report to show any unanswered to the Q extension.
Reactions: Alejandro_3CX
Hi Alexis, you could try to generate a call report from any to the queue extension number showing unanswered calls, in this way you get all the missed calls.
Yes, but it isn't automated this way, I would like it to arrive automatically every day via email. Is there a possibility?
Thank you
Change the frequency to daily..
ok sorry but I think I explained myself badly, in the call reports I can send daily but this way I will have either a graph or in any case a statistic of the missed calls, not the actual number lost as if it were a log. I don't know if I explained myself well, sorry again.
We were talking about this Call Report
mazet
