Solved Call Report Date Format
wimara
How can I change the date format on call report to Australian format (DD/MM/YYYY). It is currently showing as US date format for both CSV and HTML reports.
I've seen the following thread and have confirmed that the Debian timezone is set to AEST.
https://www.3cx.com/community/threads/date-format.53341/
The 3CX instance was setup using PBX Express and is hosted at AWS LightSail.
Thanks and regards,
Wimar
Hi Wimar,
You have to SSH into the machine and change the localization from there using Debian's guide on how to make the changes.
Thanks John, I misunderstood locale with timezone.
No problem, I would recommend to reboot the machine when done, just to ensure everything loads up with the correct locale.
Remember your previous locale in case anything goes wrong you will have to revert it so the system can resume. Run a backup beforehand just to be on the safe side.
Yeah, the change didn't take effect until it was rebooted which also fixed another issue that I was experiencing which was that the call logs were empty. Thanks again for the assistance John.
Reactions: JohnS_3CX
Glad to hear!
ICTSupport@bedfordgirlssc
