Solved Call Reports "Initializing"
Matt Horner
We've got a professional instance of 3CX, and everything seems to be working as expected. However, none of the reports are running, they're all "initialized" when the report is created. This is exactly the same for all reports, whether set to "one off" or "scheduled" report.
It's installed on a VM in the cloud so I am getting the company who we used to create in instance for us to also investigate, however they may not find anything wrong with the VM.
Emails are working fine for voicemails etc, so i don't think it's an issue with the mail side of things.
Many thanks in advance,
Hello @Matt Horner
Do you failover configured on the server? Also are all your services started?
Hi Yiannis.
thank you for the quick response. by Server do you mean the 3CX instance? or the VM that 3CX is installed onto?
we don't manage the VM at all, just the 3CX application, so i've raised it with our provider to investigate also as it's likely to be their issue, however I thought i'd post it on here incase there was anything I can check / test. When receiving email alerts and voicemails everything appears to be working fine, so i'll await their response.
thanks again,
By failover i mean is there another 3CX instance that works as a failover to this instance?
Reactions: Matt Horner
Hi Yiannis,
we don't, no, however the issue has now been resolved by the company who host's our 3CX instance, unfortunately they didn't go into detail but it's all now working as expected. Apologies for wasting your time!
Bluebox Global
