Call Reports: Name of outgoing calls not showing
asamuelson
Gold Partner
Are you referring to call reports showing which numbers were dialed for outbound calls?
Like the example from the previous post, it does not display the name of the caller, only the number on outbound calls:
I see. With outbound calls, the contacts are not searched. Therefore, I'm afraid the contact name will not match the dialed number, so it will not be reflected in the reports.
Is there any way to have the name be searched and displayed?
As mentioned, this is not an option I'm afraid.
mazet
