Call to <sip:[email protected]:0> has failed
Pav Grewal
We are seeing the following message in our logs. What could be causing this issue?
12/15/2021 1:08:41 PM - [CM503003]: Call(C:55): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
12/15/2021 1:08:41 PM - [CM503003]: Call(C:55): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
12/15/2021 1:06:54 PM - [CM503003]: Call(C:54): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
Here you go
  • 3CX Version, 18.0 Update 2 (Build 307)
  • Server OS, Hosted By 3CX
  • Is the 3CX Server Hosted and where? Hosted by 3CX]
  • IP Phone Make/Model/Firmware version, No IP Phone all using Web Client/Desktop App
  • Provisioning Method: Not sure Hosted by 3CX with Web Client/Desktop App
  • Trunk Provider or VoIP Gateway Make/Model, Skyetel, DIDlogic and Telnyx
Also how are these extensions provisioned (local, STUN, behind a SBC etc)? Not sure its all hosted by 3CX and my users are using Web Client/Desktop App.
Hi @Pav Grewal,
Are these extensions apart of a ring group by chance?
Apart from these errors, do you have any other issues?
Hi @Pav Grewal,
Yes these extensions are part of a ring group.
No I don't see any other errors.
Hi @Pav Grewal,
What you are seeing is the teardown of the Ring All call of the Ring Group when 1 extension answers it. You can reproduce this by calling the RG and answering as a different extension, you should see all extensions except the extension that answered producing a "Cause: 487 Request Terminated/INVITE from 127.0.0.1..." error.
No need to worry.
