call to voicemail getting 403 error since yesterday
Leon Zetekoff
hi there....it looks like the pbx automatically updated last night and since I can not access my VM with either the button on my GS phones or by dialing *4 from the keypad. The error in the log says no outbound route. Did this change?
TIA Leon
according to the pbx portal *4 is still to call voicemail so what is the problem?
thanks leon
i have two pbxes with the same issue
here is last part of my event log and if you click on 30052 that error has no definition
TypeEvent IDDateSourceDepartmentDetails
Warning3005212/05/2024 11:56 AMSIP ServerDEFAULTThere was no user or outbound rule found for the number *4 that Ext.701 dialed.
Warning3005212/05/2024 11:50 AMSIP ServerDEFAULTThere was no user or outbound rule found for the number *4 that Ext.701 dialed.
Warning3005212/05/2024 11:44 AMSIP ServerDEFAULTThere was no user or outbound rule found for the number *4 that Ext.798 dialed.
Warning3005212/05/2024 11:24 AMSIP ServerDEFAULTThere was no user or outbound rule found for the number *4 that Ext.701 dialed.
Warning3005212/05/2024 11:23 AMSIP ServerDEFAULTThere was no user or outbound rule found for the number *4 that Ext.702 dialed.
Activity logs​
Logging Level: All
Extension: All
Call: All
TimeMessage
12/05/2024 11:56:20.509 AML:25.1[Extn:701{2defdb276f37}] Dialed number '*4' has no route!
12/05/2024 11:50:14.900 AML:24.1[Extn:701{d552fa65430a}] Dialed number '*4' has no route!
12/05/2024 11:44:29.692 AML:18.1[Extn:798{95d4117963f0}] Dialed number '*4' has no route!
12/05/2024 11:24:15.282 AML:13.1[Extn:701{07353373768c}] Dialed number '*4' has no route!
12/05/2024 11:23:49.793 AML:12.1[Extn:702{06b32678a446}] Dialed number '*4' has no route!
Diogo Maia
