Solved Call waiting using 3CX cell phone app?
pflorence
While on a call, second call goes directly to VM. Allow multiple calls is enabled. Is there a way to have a call waiting notification?
Now testing the in App forwarding options. I will follow up soon.
Which App(iOS/Android) are you using? I'd recommend creating a new test extension and testing with the 3CX Webclient to make sure it has nothing to do with the configuration of your current extension.
This what you should see:
Android
Do let us know how it go.
All is working. Changed within the app (Android for this test) Forward external calls to "My Mobile" (Rebound)Also under Miscellaneous set Accept Multiple Calls and Accept Push Notifications.
Great to hear @pflorence, if you need anything else, feel free to open a new thread!
Mr_IT
