Callback is not working!
ltifoski
New User
Dear,
I configured the callback im my queue, but this working only with internal calls (extension to extension). How to made to working with external calls?
Thanks.
Lucas Tifoski
What licence do you have? Is it a Pro licence? Does the feature enable? Does the caller hear the prompt when dialling 2 requesting for a callback? Do you have an outbound rule matching the callback?
Yes, is a Pro licence!
the caller hears the prompt that tells the number to which to return. But the call does not disconnect and does not return. Internally, the call disconnects and callback works. It just does not work for outside calls.
Do you pass the firewall checker on the PBX? Also who is your provider? From your description your issue may be due to the fact that the call is not being disconnected. In this case you will need to set the PBX to verbose mode. Go to Dashboard / Activity log / Settings ans set the logging level to verbose. Restart all services. Then try the call back again and check the activity log for the reason the callback failed.
This is the log:
14/09/2017 08:29:32 - [CM102001]: Authentication failed for AuthFail Recv Req PUBLISH from 169.254.0.174:5060 tid=000058b5 [email protected]: PUBLISH sip:[email protected] SIP/2.0 Via: SIP/2.0/UDP 169.254.0.174:5060;branch=z9hG4bK000058b5 Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected]> From: <sip:[email protected]>;tag=500604fb9583fb3100005e05-0000167b Call-ID: [email protected] CSeq: 323468 PUBLISH Expires: 2147483647 Content-Disposition: session;handling=required Content-Type: application/pidf+xml Proxy-Authorization: Digest username="4006",realm="3CXPhoneSystem",uri="sip:[email protected]",response="af00be36bf2470b89126e63a128288c4",nonce="414d535959ba681b69:fc886567595b16ca582b889fc7884e89",algorithm=MD5 User-Agent: Cisco-CP6921/9.4.1 Event: presence Content-Length: 516 <?xml version="1.0" encoding="UTF-8"?> <presence xmlns="urn:ietf:params:xml:ns:pidf" xmlns:dm="urn:ietf:params:xml:ns:pidf:data-model" xmlns:e="urn:ietf:params:xml:ns:pidf:status:rpid" xmlns:ce="urn:cisco:params:xml:ns:pidf:rpid" xmlns:sc="urn:ietf:params:xml:ns:pidf:servcaps" entity="sip:500604fb9583"> <tuple id=""> <status> <basic></basic> </status> <contact></contact> <note></note> </tuple> <dm:person> <status> <basic></basic> </status> <e:activities> <ce:available/> </e:activities> </dm:person> </presence> ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14/09/2017 08:29:32 - [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH [email protected] tid=000058b5 cseq=323468 PUBLISH [email protected]:5060 / 323468 from(wire)
14/09/2017 08:29:28 - [CM102001]: Authentication failed for AuthFail Recv Req PUBLISH from 169.254.0.162:5060 tid=00003c8a [email protected]: PUBLISH sip:[email protected] SIP/2.0 Via: SIP/2.0/UDP 169.254.0.162:5060;branch=z9hG4bK00003c8a Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected]> From: <sip:[email protected]>;tag=500604fb93d450400000703d-0000329c Call-ID: [email protected] CSeq: 19864 PUBLISH Expires: 2147483647 Content-Disposition: session;handling=required Content-Type: application/pidf+xml Proxy-Authorization: Digest username="4005",realm="3CXPhoneSystem",uri="sip:[email protected]",response="9185595a0481cfc78c8b0b01b2cbe6fe",nonce="414d535959ba681866:bb71596f0777206268442b21c41d6cec",algorithm=MD5 User-Agent: Cisco-CP6921/9.4.1 Event: presence Content-Length: 510 <?xml version="1.0" encoding="UTF-8"?> <presence xmlns="urn:ietf:params:xml:ns:pidf" xmlns:dm="urn:ietf:params:xml:ns:pidf:data-model" xmlns:e="urn:ietf:params:xml:ns:pidf:status:rpid" xmlns:ce="urn:cisco:params:xml:ns:pidf:rpid" xmlns:sc="urn:ietf:params:xml:ns:pidf:servcaps" entity="sip:500604fb93d4"> <tuple id=""> <status> <basic></basic> </status> <contact></contact> <note></note> </tuple> <dm:person> <status> <basic></basic> </status> <e:activities> <ce:dnd/> </e:activities> </dm:person> </presence> ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14/09/2017 08:29:28 - [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH [email protected] tid=00003c8a cseq=19864 PUBLISH [email protected]:5060 / 19864 from(wire)
14/09/2017 08:29:26 - [CM102001]: Authentication failed for AuthFail Recv Req PUBLISH from 169.254.0.174:5060 tid=000058d3 [email protected]: PUBLISH sip:[email protected] SIP/2.0 Via: SIP/2.0/UDP 169.254.0.174:5060;branch=z9hG4bK000058d3 Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected]> From: <sip:[email protected]>;tag=500604fb9583fb2f00005fc4-00002ba4 Call-ID: [email protected] CSeq: 323466 PUBLISH Expires: 2147483647 Content-Disposition: session;handling=required Content-Type: application/pidf+xml Proxy-Authorization: Digest username="4006",realm="3CXPhoneSystem",uri="sip:[email protected]",response="99e9f59cf1d8b5558b843caa332abdf6",nonce="414d535959ba681602:5896874826fc066c0a4fab26a3455e21",algorithm=MD5 User-Agent: Cisco-CP6921/9.4.1 Event: presence Content-Length: 516 <?xml version="1.0" encoding="UTF-8"?> <presence xmlns="urn:ietf:params:xml:ns:pidf" xmlns:dm="urn:ietf:params:xml:ns:pidf:data-model" xmlns:e="urn:ietf:params:xml:ns:pidf:status:rpid" xmlns:ce="urn:cisco:params:xml:ns:pidf:rpid" xmlns:sc="urn:ietf:params:xml:ns:pidf:servcaps" entity="sip:500604fb9583"> <tuple id=""> <status> <basic></basic> </status> <contact></contact> <note></note> </tuple> <dm:person> <status> <basic></basic> </status> <e:activities> <ce:available/> </e:activities> </dm:person> </presence> ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14/09/2017 08:29:26 - [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH [email protected] tid=000058d3 cseq=323466 PUBLISH [email protected]:5060 / 323466 from(wire)
14/09/2017 08:29:23 - [CM102001]: Authentication failed for AuthFail Recv Req PUBLISH from 169.254.0.162:5060 tid=00002813 [email protected]: PUBLISH sip:[email protected] SIP/2.0 Via: SIP/2.0/UDP 169.254.0.162:5060;branch=z9hG4bK00002813 Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected]> From: <sip:[email protected]>;tag=500604fb93d4503e00000038-00002da0 Call-ID: [email protected] CSeq: 19862 PUBLISH Expires: 2147483647 Content-Disposition: session;handling=required Content-Type: application/pidf+xml Proxy-Authorization: Digest username="4005",realm="3CXPhoneSystem",uri="sip:[email protected]",response="c2e5b83c6cabb74e3c6d8a3cb5d4272b",nonce="414d535959ba681310:e4d4b8b4c674fe4ebafc9a47a691aa5c",algorithm=MD5 User-Agent: Cisco-CP6921/9.4.1 Event: presence Content-Length: 510 <?xml version="1.0" encoding="UTF-8"?> <presence xmlns="urn:ietf:params:xml:ns:pidf" xmlns:dm="urn:ietf:params:xml:ns:pidf:data-model" xmlns:e="urn:ietf:params:xml:ns:pidf:status:rpid" xmlns:ce="urn:cisco:params:xml:ns:pidf:rpid" xmlns:sc="urn:ietf:params:xml:ns:pidf:servcaps" entity="sip:500604fb93d4"> <tuple id=""> <status> <basic></basic> </status> <contact></contact> <note></note> </tuple> <dm:person> <status> <basic></basic> </status> <e:activities> <ce:dnd/> </e:activities> </dm:person> </presence> ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14/09/2017 08:29:23 - [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH [email protected] tid=00002813 cseq=19862 PUBLISH [email protected]:5060 / 19862 from(wire)
14/09/2017 08:29:21 - [CM102001]: Authentication failed for AuthFail Recv Req PUBLISH from 169.254.0.174:5060 tid=00007f9b [email protected]: PUBLISH sip:[email protected] SIP/2.0 Via: SIP/2.0/UDP 169.254.0.174:5060;branch=z9hG4bK00007f9b Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected]> From: <sip:[email protected]>;tag=500604fb9583fb2d00001dda-00005205 Call-ID: [email protected] CSeq: 323464 PUBLISH Expires: 2147483647 Content-Disposition: session;handling=required Content-Type: application/pidf+xml Proxy-Authorization: Digest username="4006",realm="3CXPhoneSystem",uri="sip:[email protected]",response="e65a4d56f419cd4ff6b6f180d54eea2f",nonce="414d535959ba681194:936b631557c218b9669514a05a5a3340",algorithm=MD5 User-Agent: Cisco-CP6921/9.4.1 Event: presence Content-Length: 516 <?xml version="1.0" encoding="UTF-8"?> <presence xmlns="urn:ietf:params:xml:ns:pidf" xmlns:dm="urn:ietf:params:xml:ns:pidf:data-model" xmlns:e="urn:ietf:params:xml:ns:pidf:status:rpid" xmlns:ce="urn:cisco:params:xml:ns:pidf:rpid" xmlns:sc="urn:ietf:params:xml:ns:pidf:servcaps" entity="sip:500604fb9583"> <tuple id=""> <status> <basic></basic> </status> <contact></contact> <note></note> </tuple> <dm:person> <status> <basic></basic> </status> <e:activities> <ce:available/> </e:activities> </dm:person> </presence> ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14/09/2017 08:29:21 - [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH [email protected] tid=00007f9b cseq=323464 PUBLISH [email protected]:5060 / 323464 from(wire)
14/09/2017 08:29:19 - Line 10003 got Device: Dev(804366074):[sip:[email protected]:5060 / 10003]
14/09/2017 08:29:19 - Source is identified as trunk Lc:10003(@SAÍDA-CELULAR[<sip:[email protected]:5060>])
I can see a few things wrong from the logs you posted. You are using an un-supported provider which has not been tested against 3CX so the behaviour is unknown. You are using an un-supported cisco phone which is sending its mac address to the PBX and is your DHCP server giving ip addresses in the 169.254.x.x range or non of your devices can get an IP?
my DHCP Server that provides the IPs. The provider really is not tested by 3CX, but does this really influence how callback works?
Can you help me?
whitney1984
