CallControlAPI - issues with 3cxpscompp2
alvaro.parra
I am starting to work with Call control API v16 but i am facing this error.
System.IO.FileNotFoundException: Could not load file or assembly '3cxpscomcpp2, Version=2.0.0.0, Culture=neutral, PublicKeyToken=53c4927ce4749cb4'. The system cannot find the file specified.
My guess is that your application is not written in .Net Core and perhaps not 64 bit?
I am using the 3cx_call_control_api_v16, try to run this project in:
3cx installed on windows server 2016 64bit.
Dotnet
dotnet sdk 2.1.300 win x64
aspnetcore-runtime-2.1.0 win x64
dotnet runtime 2.1.0 win x64
- Copied 3CXPhoneSystem.ini to output binary files
- 3cxpscomcpp2.dll in C:\Program Files\3CX Phone System\Bin
API on C:\source\API_EXECUTE_PATH
and call_controll_API_v16 build from command prompt with "dotnet build"
still having message
" System.IO.FileNotFoundException: Could not load file or assembly 'netstandard, Version=2.1.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'. Could not find or load a specific file. "
Allready solved,
API was working over Windows, but instalation in Debian has two paths for libs.
the 3cxpscomcpp2.dll file is in a different path to the 3cxphoneSystem files, so I had to adjust the API to change the instanceBinPath to the correct path.
thanks !!
Did anyone noticed API stop working on last update?
Reactions: Alerson Ramon
It sure seems to be broke! We were running under .Net 4.6.2 and the V16.6 update broke our code. Changed to a .Net Core 2.1 and still nothing. Digging.
Reactions: Gioal
awan05
